Personal Runbook
The system creates a built-in runbook for each map to accommodate all automation actions executed by a specific user when no runbook is open. The built-in Runbook is named with the current login username, for example, kang Runbook, which means each user can have a personal runbook on each map.
A shared map can have multiple personal runbooks if multiple users use it for collaboration. Users who work on the shared map can view, open, and modify other personal runbooks to learn and exchange knowledge.
A personal runbook can also be deleted, exported, and shared with other users. You can also save it as a runbook template.
