Manage Smart CLI Access Credentials
The system provides independent Smart CLI Settings and Smart CLI Login for Smart CLI. When you integrate the Smart CLI with your NetBrain, the Smart CLI will use the predefined credentials in Smart CLI Settings and Smart CLI Login to access devices.
- Click the
icon and select Smart CLI Settings.
- On the Login Template tab, click Add to define a template.
- See Step 2 in Define Login Template for more definition details.
Note: Manage the access credentials in the Network Settings on the Smart CLI window. See Configure Network Settings for more details.
If you want to define the access credentials for a single device, navigate to the Smart CLI Login.
Refer to the following topics to set your network credentials:
- To define the login template for reuse and quick connection, go to Define Login Template.
- To define access credentials for a single device, go to Connect Devices from Map.
