Define Login Template for Adaptive Connection
The login template is user-specific at the domain level, storing device-neutral login credentials. You can create multiple login templates to connect a device under different circumstances. Once a login template is defined, you can reuse it for device connection with one click.
- Click Connect and select New Connection or Edit Connection.
- Enter a device hostname in New Connection dialog. Select the Use Login Template check box and then click New Template from the Select drop-down list.
- Define the following items.
- Enter a template name and make a brief description.
- In the Login Settings area, enter a username and a password, then select a Jumpbox.
- Define privilege username and password if necessary.
Note: To define the login template in the other entrance, see Managing Smart CLI Access Credentials.
- Click OK.
- Once the template is created, you can manage it in the Network Setting > Login Template Manager.
