Log in to Function Portal
Use one of the following two methods to log in to your function portal.
- Username/Password Login – the user with IE accounts or portal accounts can log in using a username/password or email address.
- Access Code Login – any user can use an access code to log in.
Note: Access code login must have been enabled when power users set up the portal.
- Log in to the Function Portal with the portal URL and access code published by other users.
- Navigate to the following working areas to view the data in your portal.
- Dynamic Map
- A/B Path
- One-IP Table
Note: you will be recognized as an unknown user if you login with an access code. You can select to create a profile for user recognition and use that profile as your identity. The user profile will be listed on the User Accounts > User Profiles for Portal tab on the System Management page.
