Plugins
Add the target plugin to customize the accuracy for the foundation data model and topology.
- Add Execution Point: Define at which stage of the Benchmark to run the plugins. See Execution Point for more details.
- Recommended Settings: Enable the built-in plugins to complete the underlying data and complement the data to calculate the topology. See Built-in Plugin for more details.
- Example: Use the plugins to import the configurations.
