Built-in Plugin
The Plugin function aims to correct or fix up the inaccurate data and topology model calculated by the system. A Plugin is essentially a set of Python scripts that can be executed in the system for data acquisition, update, and revision.
Plugin NamePurposeExecution Point
Import Config
To add devices and device interfaces to the system.
Information Note: This plugin needs further customization during the execution. See Executing the Import Config Plugin for more details.
Before executing a discovery task
Import End System
To add end systems to the system and set path their gateways for path calculation.
Information Note: This plugin needs further customization during the execution. See Executing the Import End System Plugin for more details.
Topology Stitching
To modify the topology links between device interfaces.
This plugin can be added to a benchmark task at the execution point after building L3 topology.
Information Note: This plugin needs further customization during the execution. See Executing the Topology Stitching Plugin for more details.
After building L3 topology
Checkpoint Warp Topology Stitching
To establish the IPv4 L3 topology for Checkpoint virtual system and Checkpoint virtual router/virtual switch.
Identify Management Interfaces
To identify the management interface of each device and update the corresponding interface property. This successful execution of this plugin ensures the Exclude Management Interface option in the Map Settings can function well.
Note: Before running this plugin through a benchmark task, make sure that the subnet addresses of management interfaces in your network have been entered correctly as input. Here is a example:
Code
"192.168.1.0/24",
"10.10.3.253/22"
After rebuilding Visual Space
Separate ASA Firewall Failover Interfaces into Different Zones
To add failover interfaces of ASA Firewalls with the same IP addresses to different zones so that the failover interfaces can participate in L3 topology calculation.
This plugin can be added to a benchmark task at the execution point before building the network’s L3 topology.
Before building L3 topology
Separate Checkpoint Firewall Sync Interfaces into Different Zones
To add the sync interfaces of Checkpoint firewalls with the same IP addresses to different zones so that the sync interfaces can participate in L3 topology calculation.
SRX_Remove_Superfluous_Interfaces
To customize the L2 topology to connect neighbor interfaces with SRX firewalls that are configured as a chassis cluster.
