Execute a Benchmark Task
There are two ways to execute a Benchmark task:
Schedule the Benchmark Task
- Right-click on the target Benchmark task and select 'Edit' in the drop-down menu.
- In the Edit Benchmark Task window, set up the frequency for Benchmark on the Frequency tab.
- Set up the device scope, retrieve live data, CLI commands, additional operations after Benchmark and plugins for Benchmark. See Setup a Benchmark Task for details.
- Check the Enable box before the target Benchmark task.
Manually Execute the Task
Right-click on the target Benchmark task and select Run Now in the drop-down menu.
