Enable/Disable Dynamic Calculation
Click the Start Menu
and select Golden Baseline Manager. On the Dynamic Calculation tab, click Enabled.
and select Variable Mapping. On the Global Variable tab, select the target global variable, and check Golden Baseline Dynamic Calculation. Then all its mapped parser variables will participate in the dynamic calculation.
Tip: Dynamic Calculation of Golden Baseline for a specific parser variable can also be enabled/disabled individually during the definition of a data view template. See Variable Settings for more details.
Note: Only the dynamic calculation of the Golden Baseline for single-value variables, table variables, and interfaces’ table column variables can be enabled. To enable the dynamic calculation for interfaces’ table column variables, you must set an interface key.
