Discovering AWS Network in NetBrain Domain
Follow the steps below to discover the network data model in a NetBrain domain:
- On the Domain Management page, select Operations > Discover from the quick access toolbar.
- In the Discover Devices via API area, click Select API Servers to select the API servers you want to discover.
Note: To build the data model correctly, NetBrain requires CLI+SNMP access to all virtual network appliances of each AWS VPC, including the customer gateway devices (CGW), virtual firewall instances, and virtual load-balancer instances.
Note: To discover virtual appliances via SNMP/CLI, you can specify their management IP addresses in the discovery interface.
