Device Group Map
A device group map is a container map that diagrams the devices in a device group.
Once a device group is created, the corresponding device group map is generated and named with the device group name. In a device group map, you can view the connections between devices in the group. See Opening a Device Group Map for details.
In addition, you can Map Devices and Device Group.
