Create a Network Dashboard Template
The NetBrain System provides two ways to create a Dashboard Template. You can Create a Dashboard Template from scratch or Create a Dashboard Template from a Real Dashboard Instance.
Create a Dashboard Template from Scratch
- Create a Dashboard Template from Scratch
- Click the start menu
and select Network Dashboard Widget & Template. - Select the Dashboard Templates tab, point to a category in the left pane and click the
icon to select New Template. - Specify the generic information about the template, including template name (case-insensitive) and description.
- Add widgets into the template.
- Click + Widget or the
icon. All available widgets are categorized by functionality. - Click Select to pick out your interested widgets.
- Click Submit.
Tip: If you add monitor widgets into the template, click Qapp Settings to set the frequency.
- Click Save.
- Click the
icon at the upper-right corner on a network dashboard and select Save As Template from the dropdown list.
- Select the Shared Templates in Tenant category to save it as a shared template, and then enter the basic template information.
- Click OK.
