Auto Calculating Golden Baseline
Besides Defining Golden Baseline Manually, the system provides an auto-calculation mechanism to set Golden Baseline for parser variables based on historical data generated through scheduled tasks. Once a Golden Baseline is manually modified with customized rules, its auto-calculation function will be disabled. To re-enable the dynamic calculation, you must first clear the manually defined rule.
Note: Only the data retrieved through scheduled benchmark tasks, scheduled Qapp/Gapp tasks, or scheduled DVT/Parser tasks, can be involved in the Golden Baseline dynamic calculation. The data generated by on-demand tasks will not be involved in the Golden Baseline calculation. |
This section introduces the following topics:
- Enable/Disable Dynamic Calculation of Golden Baseline
- Calculation Logic for Different Variable Types
- Initial Value for Golden Baseline Calculation
