Appendix: Built-in Properties
Built-in Device Properties
The following table lists the device properties/attributes (case-sensitive).
Property/Attribute NameDescription
nameThe hostname of a device.
mgmtIPThe management IP of a device.
subTypeNameThe device type of a device.
mgmtIntfThe management interface of a device.
vendorThe vendor information about a device.
modelThe model information about a device.
verThe version of a device.
snThe serial number of a device.
siteThe site that a device belongs to.
locThe location of a device.
contactThe contact person of a device.
memThe system memory size of a device.
assetTagThe asset tag of a device.
layerThe network layer that a device belongs to.
descrThe description of a device.
oidThe system object ID of a device.
driverNameThe driver that a device uses.
assignTagsThe tag assigned to a device for applying the network-based layout style on a map.
hasBGPConfigIndicate whether a device has been configured with the BGP protocol.
hasOSPFConfigIndicate whether a device has been configured with the OSPF protocol.
hasEIGRPConfigIndicate whether a device has been configured with the EIGRP protocol.
hasISISConfigIndicate whether a device has been configured with the IS-IS protocol.
hasMulticastConfigIndicate whether a device has been configured with the Multicast protocol.
mgmtMACThe management MAC of a device.
lwap_defaultGWThe default gateway of an LWAP device.
lwap_groupThe group that an LWAP device belongs to.
lwap_priCntrllrThe primary controller of an LWAP device.
lwap_secCntrllrThe second controller of an LWAP device.
Information Note: To check more built-in device properties, navigate to Tenant Management page > GDR Data Configuration > Device Properties tab.
Built-in Interface Properties
The following table lists the interface properties/attributes (case-sensitive).
Property NameDescription
nameThe name of an interface.
ipsThe IPv4 address of an interface.
ipv6sThe IPv6 address of an interface.
ipv6LinkLocalAddressThe IPv6 local address of an interface.
mibIndexThe MIB index of an interface.
bandwidthThe bandwidth of an interface.
speedThe speed of an interface.
duplexThe duplex of an interface.
intfStatusThe state of an interface.
macAddrThe MAC address of an interface.
moduleSlotThe module slot number of an interface.
moduleTypeThe module type of an interface.
descrThe description of an interface.
routingProtocolThe routing protocol configured on an interface.
multicastModeThe multicasting mode of an interface.
mplsVrfThe name of the VRF configured on an interface.
mplsVpnThe MPLS VPN configured on an interface.
inAclNameThe inbound ACL of an interface.
outAclNameThe outbound ACL of an interface.
modeThe switch port mode of an interface.
vlanThe VLAN number that an interface belongs to.
trunkNativeVlanThe native VLAN of an interface as switch port.
trunkEncapsulationThe trunk encapsulation protocol of an interface as a trunk port.
ipUnnumberedIpThe unnumbered IP address of an interface as an unnumbered interface.
Information Note: To check more built-in interface properties, navigate to Tenant Management page > GDR Data Configuration > Interface Properties tab.
 Built-in Module Properties
The following table lists the module properties (case-sensitive).
nameThe modules of a device.
typeThe port counts of a module.
portsThe module type of a module.
snThe serial number of a module.
hwrevThe hardware revision of a module.
fwrevThe firmware revision of a module.
swrevThe software revision of a module.
descrThe description of a module.
Information Note: To check more built-in module properties, navigate to Tenant Management page > GDR Data Configuration > Module Properties tab.
