Allocate License Nodes to Your NetBrain Tenant and Domain
Select an appropriate way to allocate license nodes to your tenant and Domain.
- Allocate License Nodes to a New Tenant and Domain
- Allocate License Nodes to an Existing Tenant and Domain
Note: Before continuing with the following steps, make sure your license has been activated. |
Allocate Licenses to a New Tenant and Domain
- Log in to System Management Page.
- Select the Tenants tab, and then click Add.
- Specify a tenant name and enter the description optionally.
- Allocate the maximum number of license nodes to this tenant.
Note: The user interface is different depending on your license type.
- For the separate module License: you need to enter the maximum units for each network module in your license, such as Foundation Nodes, Cisco ACI Ports, etc.
- For Universal Pool License, you only need to enter the maximum license nodes.
- (Optional) Allocate the Function Modules for the user of Managed Service Provider (MSP).
Note: Enterprise users still need to purchase the full Node License to use the corresponding Function Module. However, for MSP users, enabling/disabling the corresponding Function Module at Tenant Level is supported.
- Click OK to submit.
- Log in to End User Page.
- Click
from the quick access toolbar, then click Select Domain from the drop-down menu.
- Select the tenant you created and click New Domain.
- Enter the domain name.
- Allocate the maximum number of license nodes to this Domain.
Note: The user interface is different depending on your license type. For the separate module License: you need to enter the maximum units for each network module in your license, such as Foundation Nodes, Cisco ACI Ports, etc.
- Click Finish.
- Select the Tenants tab, and then select Edit from the drop-down list of the desired existing tenant.
- Allocate the maximum number of license nodes to the tenant.
- Click
- Select the existing tenant from the quick access toolbar, and then select Edit from the drop-down list of the existing Domain.
- Specify a domain name.
- Allocate a maximum number of nodes to the Domain.
- maximum units for each network module in your license, such as Foundation Nodes, Cisco ACI Ports, etc.
- Click OK.
