1.Click the Windows start menu and then click the
icon to open the Apps pane.
2.Right-click the Uninstall NetBrain Service Monitor Agent app in the pane, and then select Run as administrator from the drop-down list to launch the Installation Wizard.
4.Click Finish to exit the Installation Wizard.
