1.Log in to the Linux server where the Service Monitor Agent is installed as the root user.
2.Open a command prompt, and then run the cd /opt/netbraintemp8.0.3/ServiceMonitorAgent command to navigate to the ServiceMonitorAgent directory.
3.Run the ./uninstall.sh command to uninstall the Service Monitor Agent.
4.Run the service netbrainagent status command to check whether the Monitor Agent Service exists.
