1.Run the rpm -qa|grep rabbitmq command to check whether RabbitMQ exists on this server.
[root@localhost ~]# rpm -qa|grep rabbitmq
rabbitmq-server-3.7.7-1.el7.noarch
2.If it exists, complete the following steps to uninstall it:
1)Run the cd /usr/lib/netbrain/installer/rabbitmq command to navigate to the rabbitmq directory.
2)Run the ./uninstall.sh command under the rabbitmq directory.
3)Specify whether to remove all RabbitMQ data. To remove data, type y or yes., otherwise, type n or no.
[root@localhost ~]# cd /usr/lib/netbrain/installer/rabbitmq
root@localhost rabbitmq]# ./uninstall.sh
INFO: Starting uninstall RabbitMQ ...
WARNING: Do you want to remove the data/log/config after uninstalling the RabbitMQ component?
Input [ yes | y ] if you want to remove all installation data (if your input is not 'yes' or 'y', it
will set to default value : no) :y
Input [ yes | y ] if you want to remove all installation data (if your input is not 'yes' or 'y', it will set to default value : no) :y
Loaded plugins: fastestmirror
Resolving Dependencies
--> Running transaction check
---> Package rabbitmq-server.noarch 0:3.7.7-1.el7 will be erased
--> Finished Dependency Resolution
Dependencies Resolved
Package Arch Version Repository Size
Removing:
erlang x86_64 21.2.4-1.el7.centos installed 31 M
Transaction Summary
Remove 1 Package
Installed size: 31 M
Downloading packages:
Running transaction test
Transaction test succeeded
Running transaction
Warning: RPMDB altered outside of yum.
Erasing : erlang-21.2.4-1.el7.centos.x86_64 1/1
Verifying : erlang-21.2.4-1.el7.centos.x86_64
1/1
Removed:
erlang.x86_64 0:21.2.4-1.el7.centos
Complete!
