Uninstalling Front Server
1.On the machine where Front Server is installed, open a command prompt, and then run the cd /usr/lib/netbrain/installer/frontserver command to navigate to the frontserver directory.
2.Run the ./uninstall.sh script under the frontserver directory to uninstall the Front Server.
3.Run the service netbrainfrontserver status command to ensure the Front Server service has been removed.
