NetBrain Smart CLI is an SSH and Telnet client for the Windows platform. You can use it as a standalone tool to execute CLI commands or integrate it with NetBrain IE to automatically log in to devices, execute CLI commands and send CLI results to your NetBrain IE for documentation and troubleshooting.
Note: Before using NetBrain Smart CLI, you need to install Smart CLI on Windows first.
The following is a recommended flow for using Smart CLI along with NetBrain IE:
1.Connect to Devices from NetBrain Map.
2.Execute CLI Commands in Smart CLI Window.
3.Save CLI Results to NetBrain Runbook.
4.Compare CLI Results with Historical Data to View Changes.
