1.Enter one of the following search terms in the search bar:
▪path/application name
▪IP address or hostname of the source, destination, or a hop device
Note: If a path is calculated with IP addresses, it cannot be searched out by hostname keyword, and vice versa.
2.Click the
icon or press the Enter key on your keyboard to start searching. The search results are displayed with the matched keyword highlighted.
3.Right click the target path entry and then select Draw Path on Map.
Note: If the path has not been calculated, the map will be blank.
