Built-in python files that can be called and used in many features are maintained by NetBrain engineers and cannot be modified. Besides built-in ones, you can import or write your own python files  and reuse them when required in the system.
Creating a Python File
2.In the System Management page, click Operations > Script Manager from the quick access toolbar.
3.Point to the Public category and click the drop-down menu to select New Python.
4.Rename the file and press the Enter key on your keyboard.
5.Write python scripts in the editor.
6.Click Save. The python file will be synchronized to your NetBrain Worker Servers in a few minutes.
