One map can contain multiple map pages. When you save a map, all map pages will be saved in one map file.
Tip: On one map page, the links in different topology types are supported, such as IPv4 Layer 3 topology, and Layer 2 topology. You can use the extend neighbors or auto link function to draw neighbors or links on a map.
You can perform the following operations based on your needs to manage map pages.
Adding a map page
Duplicating a map page
Renaming a map page
Deleting a map page
