The following table introduces the interface types in the system.
Interface Type
Description
Physical Interface (displayed as Physical Interface in GDR, id: "intfs")
Contains all interfaces parsed from device configuration files directly. For example, e0/0, f0/0, vlan10, and so on.
IPv4 Interface (displayed as ipIntfs in GDR, id: "ipIntfs")
Contains all interfaces created by the system for IPv4 L3 topology calculation and display. For example, vlan 10 172.24.101.32/24.
IPv6 Interface (displayed as ip6Intfs in GDR, id: "ip6Intfs")
Contains all interfaces created by the system for IPv6 L3 topology calculation and display. For example, atm4/0 2002:9:9:34::4/64.
IPsec VPN Interface (displayed as ipsecVpnIntfs in GDR, id: "ipsecVpnIntfs")
Contains all interfaces created by the system for IPsec VPN tunnel calculation and display. For example, outside peer-ip 172.27.129.114.
GRE VPN Interface (displayed as greVpnIntfs in GDR, id: "greVpnIntfs")
Contains all interfaces created by the system for GRE VPN tunnel calculation and display. For example, Tunnel0.
L2 topology
IPv4 L3 topology
IPv6 L3 topology
IPsec VPN topology
Configuring Global Data Repository (GDR)
