Instant Qapp is the fastest way to decode network design in a live network and overlay the discovered data on top of any maps. With Instant Qapp, a dynamic map becomes the single pane of glass for any network data.
Example: Visualize parser variables on a map.
The following types of parser types are supported in Instant Qapp:
Sample of Search Result |
Note: For CLI/SNMP/API parsers that contain parameters, only those containing the $intf_name parameter can be searched out in Instant Qapp.
▪Integrating with Third-Party Systems
