Select one of the following ways to install the Service Monitor Agent on each NetBrain server, depending on its operating system:
▪Installing Service Monitor Agent on Linux
▪Installing Service Monitor Agent on Windows
Note: Install the Service Monitor Agent after the installation of other components. If the Service Monitor Agent is installed prior to the installation of other NetBrain components, it will fail to retrieve the NetBrain Server Logs.
