1.On a map page, click Map > Export > Visio on the map toolbar.
2.Specify the map pages that you want to export. By default, all map pages are selected.
3.Click Start. Then a Visio file named after the map name is exported to your local machine.
Tip: The default location of the exported file is C:\Users\<your username>\Downloads. The exported file is in the .vsdx format, and you must use Microsoft Visio 2013 or higher versions to open the file.
Tip: To change the Visio template, such as logo, last updater, and filename, go to Tenant Management > Advanced Settings and import your target Visio file.
Tip: You can also schedule to update maps regularly and export these updated maps to Visio. See Scheduling Map Update for more details.
