You can document a network change task, including definition, device data and results of a node, to MS Word.
1.Open the target change management task, click the
 icon and select Export to Word from the drop-down menu.
2.In the Export to Word dialog, define the export settings:
1)Modify the document name if necessary.
2)Specify the location to save the document.
3)Select the nodes and results that you want to export.
3.Click Export.
