The following table lists the attributes of an event.
Field |
Object |
The target device that the event occurs on, displaying in either of the formats: ▪The hostname of a device. For example, BJ-POP. ▪The path name, for example, Path BJ-R1->NY-Core, in which BJ-R1 is the hostname of the source device and NY-Core is the hostname of the destination device of the path. |
Event |
The content of the event. ▪The content of the event collected from a task execution is predefined by the task authors. ▪The content of the event collected from the path calculation in the Scheduling Qapp is predefined by the system. |
First Time |
The first time when the event occurred. |
Last Time |
The last time when the event occurred. |
Count |
The total times that the event occurs. When the same event reoccurs, its count increases by one. ▪When an event is acknowledged, its count resets to 0. ▪When an event is closed, its count will not be changed anymore. ▪When an acknowledged event occurs again, its count increases by 1. |
Acknowledged |
Mark whether an event is acknowledged. |
Status |
The status of the event, Closed or Open. It always displays Open if the event is not closed. |
Executed By |
The username of the task executor. If the event is a scheduled task, it displays the username that last enables the scheduler. |
Task Type |
The task type that the event is collected from. |
From Task |
The specific task name that generates the event by combining several of the following names: ▪Qapp name ▪Gapp name ▪Map name ▪Dashboard name ▪Page name ▪Activity name |
Tip: A single event only logs one entry in the Event Console. An event duplication is identified by its content, involved device, and the task type it is collected from.
The following table lists the available options to filter events.
