The Device Details Pane provides an overall view for each device by presenting various types of network data. In the Device Details Pane, you can:
▪View and modify device/interface/module properties
▪View and modify configuration file
▪View and map topology
▪View and compare pre-built data tables (neighbor table, route table, and so on)
▪View and compare CLI command outputs that have been saved as benchmark
▪Add notes to the device
▪Customize physical images for the device
▪On a map, double-click a device.
▪On a map, right-click a device and select View Device Details.
▪In the search results, point to the device and click the
icon to select View Device Details.
▪Configuring Global Data Repository
▪Comparing Historical Device Data
