The system allows you to define command blocks following a certain format rule in the driver definition to retrieve live data.
For example, this is a command block to retrieve route tables with multiple VRF instances.
CommandBlock::[["su $vrfName", ["BR-K6-Albright-G27(su-secure)>", "show ip route"],
["regex:\s\S+>", "Y"], ["regex:\s\S+>", ""]]]
The following table explains the format rule in detail:
Command Block Element
Explanation
CommandBlock::[[  ]]
Precursor string, indicating the following content is a command block (JSON array).
“su $vrfName”
The first command in a command block, which is also the only one that will be issued without any conditions.
Command pairs, including the expected prompt and responsive command. Multiple string pairs can be attached in a command block.
Tips: Regular expression can be used to define an expected prompt. The Ctrl + C keys and whitespace can be used to define a responsive command.
