Customizing Login Logo and Banner
By default, the logo image of NetBrain is displayed on the login page, and there is no banner.
To customize the logo and banner on the login page, do the followings:
1.Log in to the System Management Page.
2.In the System Management page, select the Advanced Settings tab.
3.In the Login Interface area, click Upload Logo.
Tip: To rollback to the default image, click Restore Defaults.
4.To add a link to the image so that users will be redirected to the webpage when they click the image, you need to enter a full URL. For example, https://www.netbraintech.com.
5.To add a login banner, select the Enable Login Banner check box.
1)Add a title.
2)Add a paragraph you want to display.
6.Click Save.
