Customizing Auto Link Options
1.On a map page, click Map > Map Settings on the map toolbar.
2.In the Map Settings pane, rotate the mouse wheel button backward to Auto Link between Nodes area, then select the topology types that will be auto-linked on your map.
3.Click Set as Default. This change will be applied to all your new maps and new pages as default settings.
Topology
Auto Link
