Content Settings determine what contents are included in the exported document from a map. The left side of the setting pane reflects the table of the content of the document, which can be renamed, moved up/down, and removed. The right side reflects the text of the document.
The following table introduces the options in Content Settings.
Section |
Explanation |
Topology Map |
▪Visio Map — a Visio map is embedded in the Word document. |
Path |
▪Property — the path properties, such as name, direction, and data source. ▪Path Overview — the path general information, such as path number and device note related to the path. |
Device Configuration |
▪File Type — you can select the Full Configuration, or select a specific configuration from the drop-down list of Configlet. ▪Display Mode — the layout of the device configuration. Two modes are provided: Horizontal and Vertical. |
Device Asset Data |
You can select the desired device asset data to export. By default, the following asset data are selected: ▪Hostname ▪Mgmt IP ▪Device Type ▪Vendor ▪Model ▪Software Version ▪Serial Number Note: Hostname cannot be moved. |
Data Table |
Select data tables to export, such as Route Table, NDP Table, and NAT Table. |
Data View |
Data Table — data table of devices related to the data view. Monitor Chart — Only include charts with errors or warnings. |
