The system offers several built-in CLI templates for you to bulk add CLI commands into your tasks, and also allows you to create your own templates. Inside a template, you can define the applicable device types for each CLI command as qualifications. Then, by loading a CLI template into your tasks, such as Runbook, Benchmark and so on, you can leverage the predefined qualifications to exclude the improper commands from the execution scope.
Note: You can add different device types for a single CLI command in different templates. When you add duplicate commands by loading templates into a task, the device types defined in different templates will be combined.
