If your third-party API system supports python script inputs, you can launch a pre-defined API-triggered diagnosis task through the following sample scripts (replace highlighted sample parameters with real instances):
import requests
import json
import time
import requests.packages.urllib3 as urllib3
urllib3.disable_warnings()
# Need to install requests package for python
# pip install requests
user = "admin"
pwd = "admin"
host_url = "http://10.10.0.29" #NetBrain system address
headers = {'Content-Type': 'application/json', 'Accept': 'application/json'}
Get token for netbrain
TENANT = 'Topo' #tenant name
DOMAIN = 'Flow' #domain name
def getTokens():
login_api_url = r"/ServicesAPI/API/V1/Session"
Login_url = host_url + login_api_url
data = {
"username": user,
"password": pwd
token = requests.post(Login_url, data=json.dumps(
data), headers=headers, verify=False)
if token.status_code == 200:
print(token.json())
return token.json()["token"]
else:
return "error"
# get token
token = getTokens()
headers["Token"] = token
def get_tenant_domain_id():
tenant_id_url = '/ServicesAPI/API/V1/CMDB/Tenants'
full_url = host_url + tenant_id_url
data = requests.get(full_url, headers=headers, verify=False)
tenant_id = ""
domain_id = ""
print(data.json())
if data.status_code == 200:
for tenant in data.json()['tenants']:
if TENANT == tenant['tenantName']:
tenant_id = tenant['tenantId']
if tenant_id:
domain_id_url = '/ServicesAPI/API/V1/CMDB/Domains'
full_domain_url = host_url + domain_id_url
domain_data = requests.get(full_domain_url, params={'tenantId': tenant_id}, headers=headers, verify=False)
print(domain_data.json())
if domain_data.status_code == 200:
for domain in domain_data.json()['domains']:
if DOMAIN == domain['domainName']:
domain_id = domain['domainId']
return tenant_id, domain_id
else:
def Logout():
logout_url = "/ServicesAPI/API/V1/Session"
time.sleep(2)
full_url = host_url + logout_url
body = {
"token": token
result = requests.delete(full_url, data=json.dumps(
body), headers=headers, verify=False)
print(result.json())
if result.status_code == 200:
print("LogOut success...")
else:
data = "errorCode" + "LogOut API test failed... "
return data
# Trigger API function
def TriggerTask(API_Body):
# Trigger API url
API_URL = r"/ServicesAPI/API/V1/Triggers/Run"
# Trigger API payload
api_full_url = host_url + API_URL
api_result = requests.post(api_full_url, data=json.dumps(
API_Body), headers=headers, verify=False)
if api_result.status_code == 200:
return api_result.json()
else:
def stopTask(taskid):
stop_url = '/ServicesAPI/API/V1/Triggers/Stop/'
full_url = host_url + stop_url + taskid
data = {
api_result = requests.post(full_url, data=json.dumps(
return api_result
if __name__ == "__main__":
tenant_id, domain_id = get_tenant_domain_id()
print(tenant_id, domain_id)
# tenant_id = 'd5436528-2b8a-e908-4c39-b07e7aaa11a9'
# domain_id = '22d163f6-e2b1-48ca-99e8-88ab47809db4'
API_BODY = {
'domain_setting':
'tenant_id': tenant_id,
'domain_id': domain_id
'basic_setting':
'user': 'admin',
'device': 'BJ*POP', #any device in NetBrain system
'stub_name': 'stub2', #API task to trigger
'triggered_by':"Netbrain"
'map_setting':{
'map_create_mode':3, # 3 means creating a path map
'map_path_para':{
'source': '172.24.31.195',
'destination': '10.10.7.235',
'direction': 1, # 1 means creating one-way path
'isLiveUseBaseLineConfig': True,
'advancedOption': {
'debugMode': False,
'calcL3ActivePath': False,
'useCommandsWithArguments': False,
'calcWhenDeniedByACL': False,
'calcWhenDeniedByPolicy': False,
'pathFixUp': False
print(TriggerTask(API_BODY))
