The identified changes in comparison results are categorized as follows:
Category |
Added |
The data only exists in the second data source or time period. |
Modified |
The data exists in both the first and the second data source or time period but has changes. |
Removed |
The data only exists in the first data source or time period. |
Equal |
The data exists in both the first and the second data source or time period, and no changes occur. |
Note: The comparison results for the same device and data type may be different if you swap the Dataset 2 and Dataset 1 during the comparison, because the Comparison feature takes Dataset 2 as a reference and uses the Dataset 1 to compare with it. For example, a comparison result shows that a route entry has been added, but it will show removed when you swap the two data sets.
