Application Manager enables you to manage traffic paths based on applications and verify the application paths periodically to detect possible network changes and ensure application consistency.
The following is a recommended flow for verifying paths in batch in the system:
1.Define Applications and Paths.
2.Define Golden Paths for Application Paths.
3.Verify Application Paths Automatically.
4.View Results and Generate Report.
5.Troubleshoot the Path Changes with Runbook Automation.
