Advanced search allows you to build complex search queries to search for devices by using multiple search criteria and a boolean expression.
1.Click the search bar and then select Advanced Search from the drop-down list.
2.Specify the scope to search for devices.
3.Set search criteria A based on your needs:
1)Select a data source and a property from the first drop-down menu.
2)Select an operator from the second drop-down menu.
3)Specify the value of the property that you selected.
4)Repeat to set more conditions if required.
4.Define the condition combination in the Boolean Expression field. For example, A and B.
6.Click Search. The searched result is displayed as follows:
The following table lists the available components in an advanced search.
Component |
Option Values |
Search Scope |
The scope of devices. |
▪All Devices — all devices in the current domain. ▪Site — devices in one or more sites. ▪Device Group — devices in one or more device groups. |
Search Criteria |
Property |
▪Device Property — use one or more device properties to find devices. ▪Interface Property — use one or more interface properties to find devices. ▪Module Property — use one or more module properties to find devices. ▪Config File — use texts in the configuration file to find devices. ▪Front Server — use a Front Server or Front Server Group to find their managed devices. |
Match Operator |
Specify multiple values by separating them with a semicolon (;). ▪Match/Does not match — The full-text search pattern will be applied. ▪Contain/Does not contain — The * and ? characters are treated as either wildcards (only for a single term) or separators. |
Boolean Expression |
The logical relationships among search criteria. |
▪Capitalized letters to represent the search criteria (A, B, C ....). ▪Boolean operator (and/or), which is used to define the logical relationships among the search criteria. By default, the and operator is used. ▪Parentheses, which is used to combine some search criteria. |
