Adding Paths to Path Browser
When you calculate a path and save it, the path will be automatically added to the Path Browser.  Additionally, you can also manually add paths in the Path Browser through the following steps:
1.Click Path Browser on the taskbar.
2.Click New Path.
1)Enter a name for the path.
2)Select an application for the path.
3)Enter the source/destination IP address.
4)The related gateways will be auto-identified as per your inputs. If a device has multiple gateways, you can select the target one from the Gateway list.
5)Specify the path protocol to be used. See Path Settings for more details.
3.Click OK.
Tip: To calculate the path, right-click the entry in the Path Browser and select the corresponding options based on your needs.
Recalculating a Path
