Log in to the Domain Management page.
1.In the Domain Management page, click Schedule Task on the Start Page or select Operations > Schedule Task from the quick access toolbar.
2.On the Schedule Qapp tab, enable the built-in task Highlight Routing Protocol.
By default, the built-in Qapp task will auto-generate a static data view.
3.Click the task name to edit the Qapp task by the following wizard.
1)On the Basic Info tab, click Next.
2)On the Target Devices tab, click Next.
3)Keep the Qapp selected. Click Next.
4)On the Time Settings tab, set a proper execution time and frequency. For example, set the frequency to Daily. Click Next.
5)On the Output tab, click Finish.
▪Gapp
▪Site
