Scheduling Data View Template/Parser Task
To instantly visualize the values of concerned parser variables in a data view template, you can schedule a Data View Template/Parser task to retrieve and parse network data regularly. Once scheduled, the task is auto-enabled, and can also be triggered through Benchmark.
2.In the Domain Management page, click Schedule Task on the Start Page or select Operations > Schedule Task from the quick access toolbar.
3.On the Schedule Data View Template/Parser tab, click Add Task.
1)Specify a run time and a frequency to run the task.
2)Specify a device scope. Both legacy devices and logic nodes can be added to a task.
3)Specify the parsers to retrieve and parse data via two methods:
Select data view templates to apply all referenced parsers inside. You can also select them by folder so that folder content change can be synced.
Select parsers directly from Parser Library.
Note: The Max Command Instances for one Parser field is used to limit the generated CLI command instances for each device included in this task. By default, the value is 32. If the parsers you select or refer have parameters, you can assign a smaller value to avoid devices overloaded due to the execution of too many CLI commands.
4)Specify who will receive alerts generated during the task execution. See Sharing Golden Baseline Alerts for more details.
4.Click Submit.
