Saving as Runbook Template
To share knowledge with junior users, you can save a golden runbook as a runbook template. When saving a runbook to a template, you can select which result to be saved. Only the selected action results of the action nodes will be saved to the template as the inputs. The target devices and execution results of these action nodes will be discarded.
1.Click the icon to select Save as Runbook Template.
2.Select the action nodes that you want to include in the template, and then click Save. If an action has multiple execution results, you can click each execution result to browse its action input and pick out an appropriate one.
3.Specify a meaning name for the template and then specify a location to save the template. Click OK.
4.Click Runbook Template on the taskbar to Navigate to the Runbook Template Manager to browse the saved template.
