1.Click the icon from the taskbar and select New Qapp from the drop-down menu to open the Qapp Editor.
2.At the Start node, use the default option Map in the Define Qapp Device Input field. It means that the Qapp takes all devices visible on the map as the input devices.
3.Extend a Canvas node from the Start node and double-click the Canvas node to enter the Canvas editor.
