The system offers four group of built-in parameters:
▪QoS
▪Protocol
▪URL
▪Application
Tip: To view the built-in parameters, in the Domain Management page, navigate to Operations > Domain Settings > Path Parameters Settings.
These built-in parameters are defined in JSON as follows:
Built-in QoS Parameter Script:
{"name":"group1", "type":"group", "label":"QoS", "value":"", "enable":true},
{"name":"CoS", "type":"int", "label":"CoS Value", "value":"", "enable":true},
{"name":"DSCP","type":"string", "label":"DSCP Value", "value":"", "enable":true},
{"name":"Precedence", "type":"int", "label":"Precedence Value", "value":"", "enable":true},
{"name":"QoS-Group", "type":"int", "label":"QoS-Group Value", "value":"", "enable":true},
{"name":"group2", "type":"group", "label":"Protocol", "value":"", "enable":true},
{"name":"Protocol", "type":"string", "label":"Protocol Value", "value":"", "desc":"Identify the protocol is IPinIP or IP", "enable":true},
{"name":"group3", "type":"group", "label":"URL", "value":"", "enable":true},
{"name":"URL", "type":"string", "label":"URL Value", "value":"", "desc":"Identify the url", "enable":true},
{"name":"group4", "type":"group", "label":"Application", "value":"", "enable":true},
{"name":"Application", "type":"string", "label":"Application Value", "value":"", "desc":"Identify the application", "enable":true}
A QoS parameter contains the following properties:
Property Name |
name |
The name of the parameters for four groups: QoS, Protocol, URL, and Application. The names that be recognized by the system in the current version are as follows (case sensitive): ▪QoS: CoS, DSCP, Precedence, and QoS-Group ▪Protocol: Protocol ▪URL: URL ▪Application: Application |
type |
The value type of a parameter, such as int and string. |
label |
The display name of a parameter in the GUI. |
value |
The default value of a parameter. |
enable |
Decide whether to display a parameter in the GUI. The value is true or false. |
