To determine which data changes are included in the report, complete the following steps to configure the Change Analysis Settings.
Note: Only the users with Domain Management privilege can modify the CA Settings.
1.Log in to the Domain Management Page.
2.In the Domain Management page, select Operations > Domain Settings > Change Analysis Settings from the quick access toolbar.
3.In the Change Analysis Settings pane, configure the following settings:
1)Select the Enable Change Analysis check box.
4.Click Save.
Tip: Change Analysis Settings can also be launched by clicking Go to Change Analysis Settings in the CA Report interface.
