In the Network Change pane, you can view and manage all network change tasks in your domain.
Follow the steps below to view network change tasks in your domain:
1.Click Network Change on the taskbar.
2.In the Network Change pane, view the network change tasks. Each task includes the following information:
Field |
Change Name |
The name of a network change task. |
Status |
The status of a network change task. It includes five types of status: ▪Planning — indicates that the task is in planning and not sent for approval yet. ▪Pending — indicates that a network change is waiting for approval. ▪Approved — indicates that a network change is approved by an approver. ▪Rejected — indicates that a network change is rejected. ▪Archived — indicates that a network change is archived. |
Creator |
The creator of a network change task. |
Approver |
The approver of a network change task |
Executor |
The executor of a network change task |
Last Activity Date |
The date when a network change task is last executed. |
3.Click the Scheduled Tasks tab to view the information of the scheduled tasks in your domain. A scheduled task has 6 types of status.
▪Waiting — indicates that the task awaits to be executed. It cannot be edited.
▪Running — indicates that the task is being executed.
▪Stopped — indicates that the task is stopped manually.
▪Executed — indicates that the task is executed.
▪Aborted — indicates that a scheduled task is aborted because it does not start before the specified time.
▪Stopping — indicates that the task is being stopped.
You can quickly find a network change task via the following methods:
▪Search by Keywords — enter a keyword in the search bar and press the Enter key on your keyboard to start searching.
▪Filter by Time — select the start date and end date respectively, and click the icon to start filtering.
▪Filter by Status — click the Status drop-down list and select a status. Network change tasks will be automatically filtered by the selected status.
Tip: To reset the criteria for search or filter, click Reset.
You can also share a network change task as follows:
1.Right-click a task entry and select Share from the right-click menu.
2.In the Share Map dialog, enter the email addresses in the To field, or click the To field and select a user from the drop-down menu.
3.Click Share. The task will be shared via the map link.
