The following table describes the parameters that can be configured when installing Ansible Agent.
Parameter
Default Value
Description
AnsibleKey
abc123
Specify the key used to authenticate the connections with Ansible Agent.
BindIP
0.0.0.0
Specify the IP address of Ansible Agent.
Note: Modify the value only if you have multiple network cards on this machine.
Port
50051
Specify the port that the service of Ansible Agent listens to. Keep the default value as it is.
LogPath
/var/log/netbrain/ansibleagent
Specify the storage path for all log files of Ansible Agent.
UseSSL
no
Set whether to enable the encrypted connections to Ansible Agent by using SSL. For detailed requirements of SSL certificates and keys, see Appendix for more details.
Certificate
/etc/ssl/cert.pem
Specify the storage path for all the certificates and key files used for SSL authentication.
Note: It is required only if UseSSL is enabled.
PrivateKey
/etc/ssl/key.pem
Specify the name of SSL private key file.
