Activating a Trial License
A free trial license lasts 14 days with 300 device nodes and 25 seats.
2.In the System Management page, select the License tab and click Activate. The activation wizard prompts.
Note: If your NetworkBrain Application Server does not have access to the internet, you can configure a proxy. Click the icon at the upper-right corner, select the Use a proxy server to access the internet check box and enter the required information.
3.Activate your trial license:
1)Select Start a 14-day Free Trial and click Next.
2)Enter your email address and the activation key that you received from the system.
3)Click Activate.
4)When the activation succeeds, a notification dialog box will prompt. Click OK.
4.A confirmation dialog box prompts to ask you whether to generate an initial tenant. Click Yes and an initial tenant will be created automatically with limited nodes and seats assigned. If you click No, you can create a tenant manually later. See Creating a Tenant for more details.
5.To browse license information, navigate to License > Current License Term.
