Uninstalling Index Server
1.On the machine where Index Server is installed, open a command prompt, and then run the cd /opt/netbraintemp/Elasticsearch command to navigate to the Elasticsearch directory.
2.Run the ./uninstallelasticsearch.sh script under the Elasticsearch directory to uninstall the Index Server.
3.Run the service elasticsearch status command to check whether the Index Server service exists.
