Uninstalling Front Server
1.On the machine where Front Server is installed, open a command prompt, and then run the cd /opt/netbraintemp/FrontServer command to navigate to the FrontServer directory.
2.Run the ./uninstall.sh script under the FrontServer directory to uninstall the Front Server.
3.Run the service NetBrainFrontServer status command to check whether the Front Server service exists.
